Penryns 1333mHz Bus limits overclocking?
1 Mar 2007
London
Wondering what peoples thoughts are on Penryns running 333FSB as standard. This means that comparing to a Conroe (266mHZ) clocked at the same speed, they have lower mulitpliers. Unless your running an Extreme model with unlocked mulitplier, isn't that going to limit your overclock? So the cheapest quad Penryn the Q9300 runs at 2.5Ghz stock with a 7.5 multi and the Q6660 runs at 2.4Ghz but with a 9 multi. So if you have a WCing and a suitable MB, A 400FSB will get the Q6660 to 3.6GHz, but the Q9300 will need all of 480FSb on the MB to get to the same clock. Sure its going to run cooler, but I guess not many people will have MB and ram capable of running a 480FSB stabley long term. If your on air cooling then the Penryns may be a better bet, but if your have WC I wonder if the higher multi Conroes would OC higher?
A lot of ES Penryns have an FSB wall at 470mhz. Mine is stable right upto 454FSB without much effort, totally hit and miss to get it higher.
Penryns will be fantastic straight out of the box. Watercooling will be just for silence. With the execption of the QX chip.
Edit: highest clock I have managed to capture:
http://valid.x86-secret.com/show_oc.php?id=274661
What motherboard was that on?
Whooa I missed a trick I think. Is the 9550 CPU out yet or are you just a luck so-and-so weescott? I had thought they were due early next year?
If they are out to buy now that could solve my dilema over my next upgrade!
I dunno, that screenshot from weescott although not necessarily stable is a 1.1ghz OC... not to be sniffed at.
True, but the Q9550 is going to be a £300 and up chip when released. Plenty of cheap Q6600's are doing that clock. The Penryns with high multi have shown to get well over 4Ghz on air, but its the cheaper low multi quads I'd be interested in. If it looks like the cheaper Penryns wont clock especially well, I might just plump for a Q6600.
you need to look at the bench results too, clock for clock the penryn seems to hammer the kentsfield. For example a mid 3ghz penryn pulling sub 10s 1mb super iirc. Either way it was doing times that would have needed 6-800mhz more on a kentsfield.
Kentsfield IS penryn. :p
Sorry Matt but thats just wrong! It takes a mid 4Ghz Yorkfield to do under 10 second Super PI. And roughly 500mhz less than Kentsfield.
On the whole Yorfield is 200 to 500mhz faster clock for clock than Kentsfield depending on the application.
It's an ES chip. These wont be out till next year. :)
ok fair enough on the specifics I really don't have the attention span to keep up with the names etc, my point was how much faster that chip you have seemed clock for clock than say a Q6600.
I recall seeing a sub 10s superpi? or was I drunk (again)?
Drunk? Allmost Scottish m8 :p
There are loads of QX9650's doing sub 10 second 1mb SuperPi runs (at about 4.6Ghz), its actually kina boring now! Just over 10s on Air too.
Wolfdale CPU's are what I am waiting for. :D
