- 17 Jan 2006
I have an old Pentium3 866mhz comp at home which I have been using to purely for playing music on. As it's so old it's a bit noisy but as I don't have it on that often it's not too bad.
Howver, I am going to be moving soon, and would like to be able to use this comp more, mainly for playing music at night when all else is quiet, so really I need to do a bit of work on the comp to make it rather quieter.
The first step I think is to replace the stock CPU cooler with something rather newer and quieter, but I'm having trouble finding anything very much. Does anyone have any recommendations for models that I should look for???
The next step I guess is looking at the graphics card cooler. IIRC it's an AOpen PA256 MXII card which is a Geforce2 MX card, which while not very powerful does the job perfectly. Are there any coolers about for these?
Ideally I'd like to spend as little as possible on these bits, and for them to be as quiet as possible...any thoughts anyone??
Ta muchly in advance for any help anyone can give me.
Valve
Valve
