Pentium M giving me hassle
12 Jun 2005
A lake!
Only got this today, with a CT-479. Everytime I start up it says "New CPU installed, press F1 for setup or F2 to load defaults"
My board is an Asus P4P800E-Deluxe with the latest BIOS, how can I stop it doing this?
I think it was to do with that missing pin, have you tried a bit of wire in the socket like i suggested in the for sale thread, that seemed to fix it.
I figured it was that, and I've put wire in it. Maybe I need thicker wire?
Sweet glad to see you got it sorted, i'm not sure i'll check if i have any screenies,
Looks like 1.45v was used as it overvolted by about .03v not sure if it was needed just thats what was used
Awesome, cheers mate! :D
I stuck my Arctic Freezer on there, temps don't go over 41C at 2.6Ghz.
Now all I need is some of that 2GB OCZ Platinum PC3200. :o
Nice! So it beats the Athlon 64 clock for clock as my 3500+ is at 2.65 and my best super pi time is 32s.
Nice overclock :cool:
i think you may need the boot block trick... thats what i had to do with my old p4c800 (NON-E ) dlx when i flashed with E dlx bios (diff lan, and raid iirc) so i lost onboard lan.
found this info...
stryg in the opeinging post of the Xtremesystems CT479 thread said:
Bootblock flashing
- New versions of Afudos can´t flash the bios in if the ROMID´s are different (ex. P4C800 & P4P800-E). Thats why you must use old Afudos version that allows flashing rom´s with different ID´s (get it here). The only problem is that the older v1.16b version dont flash the bootblock automatically unlike the new versions, so you must flash the bios in with following command "afudos /iromname.rom /n /pbnc". If you don't use the following command, your board won't post after the update.
also see this thread... http://www.abxzone.com/forums/showthread.php?t=95280&page=1&pp=15
hope that helps.
