Lo all,
I did a bit of research last night after I decided to purchase season 5 of Lost in HD. I probably should have done the research first.
Anyway, from what I can gather the HD content is 720p which is fine, I knew that before I bought it but the bitrate is below 5MB/s which is less than DVD bitrate.
Now, is this a bit like .mp3's from iTunes: day-to-day it's perfectly fine unless you're an audiophile-uber-geek that has to have the biggest numbers and the best stats or do people consider it a serious issue?
After watching the first episode I did notice that the image seemed quite noisy but this could be because I'm not used to HD content on my MBP. SD content probably doesn't show the noise because of the low resolution.
To be honest, the noise didn't really bother me, Lost is quite dark and they must have needed to use a high ISO when shooting, to get an adequate frame-rate. However, I did notice the occasional bit of tearing which is a bit off-putting and I would have thought my MBP could have coped better with it.
The other thing I have to ask is about movies in iTunes, it seems you can only get HD movies through AppleTV which is ridiculous. I can see why they do it, because no-one would buy an ATV if they could get HD movies on their computer, it's still a pain though.
I would quite happily buy a Mac Mini to use as an HTPC but not if I can't get HD films through it. I would buy an Apple TV but the storage isn't big enough and I certainly don't want to have to buy both to do the same job... it seems this whole area is in limbo with Apple at the moment and there isn't a conclusive answer.
I wonder if they will do an iTunesPlus type thing, where people who have bought SD content will eventually be able to upgrade it all to the HD version for a small fee... However, £10 for films like Rock 'N Rolla seems a bit steep if you then have to add on a couple of quid at a later date to get it in HD.
Sorry for the mad ramblings, this has just been on my mind. So what do you guys think?
Panzer
Panzer
