Easy, just look for the highest RPM.Prefrably with high cmf but all welcome
Yate Loon's bearing/motor keeps ticking/chuffing noise, so does Sharkoon System Fan and Fractal design looks just like repainted Sharkoon.why?Acoustics is entirely different thing in 140mm size...
That Akasa is the worst fan I've ever listened by having incredibly loud sleeve bearing and resonating plastics.
Xigmatek uses transparent bling bling plastic so there's good probability for it to resonate like Akasa.
And never trust any stock fans of case manufacturers. (Lian Li's 120mm fans are acoustically bad like Antec Tricools)
They look like big brother of SlipStream (which is acoustically superior and has 25+% higher airflow per RPM than standard 120mm fans) so unless someone screwed up they might be acoustically best "140mm" fans... with 120mm attaching holes.what do you think about the scythe kaze 140mm they come at several rpm?
Like EsaT says, they only have 120mm mounting holes so they will not fit a 140mm radiator.
sharkoon
