Ok so my performance index keeps failing with an error.
I do have the latest drivers for my gfx card. thats the only bit of the report i can make some sense of is something about d3d ? so i just figured maybe a gfx problem but the card is running fine from what i can tell.
heres the log
030201 (0844) - winsat\logging.cpp:0815: --- START 2009\7\13 22:08:30 PM ---
030232 (0844) - winsat\main.cpp:4301: Command Line = "D:\Windows\system32\winsat.exe" moobe -cancelevent 849bd0b4-8fa1-4e71-8c56-8fdbbf2e34d1 -moobegoevent 27423f94-1309-49e2-9e93-e31a7cd77d2f
030232 (0844) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
030357 (0844) - winsat\main.cpp:4474: > IsFormal=TRUE IsMoobe=TRUE.
030420 (0844) - winsat\main.cpp:4585: Watch dog system enabled
030420 (0844) - winsat\main.cpp:4592: Main watch dog timer set to 60.0 seconds
030638 (0844) - winsat\main.cpp:2505: > DWM not running.
031746 (0844) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
031761 (0844) - winsat\main.cpp:2793: > power policy saved.
031886 (0844) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
031902 (0844) - winsat\main.cpp:2814: > power policy set to maximum.
032307 (0844) - d3d\dx9misc.cpp:1030: HRESULT = 8876086a
032323 (0844) - d3d\dx9misc.cpp:1030: Error: Unable to create the D3D device
032323 (0844) - d3d\dx9misc.cpp:1030: Error: Unable to check the capabilities of the video card because a d3d device could not be created
032463 (0844) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
032463 (0844) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=TRUE RanOverTs=FALSE RanOnbatteries=FALSE
032479 (0844) - winsat\main.cpp:1775: > Run Assessment features
033009 (0844) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
033150 (0844) - d3d\graphicsop.cpp:0263: Driver is not WDDM; aborting assessment.
033446 (0844) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 0
033462 (0844) - winsat\main.cpp:2037: > DWM Assessment results processing SUCCESS
033524 (0844) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 0
033540 (0844) - winsat\processresults.cpp:1274: Limiting DWM Score to 1.0 - no DX9 capability
033540 (0844) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 0
033571 (0844) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=TRUE RanOverTs=FALSE RanOnbatteries=FALSE
033680 (0844) - winsat\processresults.cpp:1274: Limiting DWM Score to 1.0 - no DX9 capability
033696 (0844) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 0
033696 (0844) - common\winsatutilities.cpp:1382: cannot access the winast API registry key; 2 The system cannot find the file specified.
033789 (0844) - winsat\main.cpp:2339: > Finalized MOOBE key
033836 (0844) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
033836 (0844) - winsat\main.cpp:2855: > Power state restored.
033852 (0844) - winsat\main.cpp:2873: > Not necessary to reenable EMD cache.
033945 (0844) - winsat\main.cpp:2899: INFO: DwmpRestartComposition() did not return OK!
033961 (0844) - winsat\watchdog.cpp:0311: Watch dog system shutdown
033977 (0844) - winsat\main.cpp:4909: > exit value = 0.
heres the log
