Performance & price chart for Binned CPUs (May 2018)
7 Dec 2015
Clock and price data were grabbed from a well known retailer selling binned CPUs.
Note that the 8600K is the only one here without hyper-threading so it's approximated as a quad-core.
The 8600k being listed as a 4 core, with an excuse of it doesn't have hyperthreading, when none of the others have hyperthreading taken into account kinda make the entire chart useless, unfortunately.:confused:
I find binned CPUs a bit of a pointless venture. A good percentage of retail samples will hit these speeds, albeit they may require fairly high voltage. you
Yer, the 8600k is being badly underrated imho. HT is not worth half a core, more like 20-25% tops. It should be ranked as a 5 core unit :> But even then it wouldn't be a good comparison.
That said, those 8700k 5.0s are remarkably reasonable... I was tempted by one from OCUK but the £550 price tag turned of me off again. From what I've read, the 4.9s are the dog chips, and more will do 5.0 than not...
Those are done at stock speeds though, where the 8600k is scoring 5% better at 14% lower clocks. Equalise the clocks and it's going to be 19% (at least) faster. Which is almost the 5th core :)
Even if you don't agree that the 8600K has almost identical benchmark numbers as the 7700K does (as shown at #6 of this thread), you can use your finger to block your eyes from seeing the four rows of the 8600K, making the 29 remaining rows of the chart useful :p
You win that point ^^^^ ;)
Personally I can't see why anyone would buy a binned, delidded, not-top-of-the-range chip in the first place...
Stock:
7700K: 4.5GHz singe and 4.4GHz quad
8600K: 4.3GHz single and 4.1GHz hex
It's just an error margin within 5%.
Will top it?!
We for outright performance it will be near the top but that chart really is all about performance/cost - where the AMD chip excel... TR would be very high but i dont think it would take the 2600 which seems to be the best.
Recon the top TR will beat the 7980xe price/performance ratio by a long way.
Where did the chart come from? Link?
Or did you create it yourself?
What do the colours represent?
We need a bit more info to see if it has any use.
It's from a well known US site. The colours represent what you would expect green is good red is not so good. The darker the colour the better or worse they are i.e. the 7980 XE is very strong multithreaded but poor value as its cost is high.
It does show some interesting, but well known, data.
Intel has some very high speed cpus at the top but they are also very poor VFM as they cost a fortune, meanwhile there more modestly priced stuff lower down doesnt have the grunt to match the cost being asked for.
AMD has very good priced cpus at the bottom with very good performance for there cost so earn a greener colored box and a better cost to performance ratio figure.
However as threadripper is MIA its not complete as that would put the TR chips way into the green with multicore performance (like the top intels) and keep a very high cost-performance ratio like the normal AM4 ryzens.
Why no stock performance numbers
The clock price ratio number and price performance ratio numbers are far to complicated, why go to 9 decimal places, its just ridiculous.
I cant imagine any site worth its salt using such a flawed chart.
