Hi,
Trying to determine which would be the best path for an upgrade - cpu or gpu.
Doing some testing, using the game I'm playing mostly at the moment - GRID.
Using 2 3870's, on an asus A8R32MVP, Amd X2 @ 2.7ghz, 2GB mem on XP.
Running grid on medium settings, 1920x1200, AA on "Level 1", vsync off.
On single card on above settings I'm getting reasonable fps in the menu screen (40), and in game its pretty constantly at 30 or so and quite playable.
Switched on crossfire, and the game gets worse?? 36 in menus and a huge drop in-game (struggles to get to 20+), which makes its pretty much unplayable. Checked with GPU-Z to confirm when the 2nd card is under load or not. In Crossfire mode, both cards appear to be pretty much maxing out?
The only place I see noticeable improvement is the loading screen 3D text sections where it's around 75% faster with CX enabled.
I'm confused - it seems to show a GPU limitation but why so much of a hit with crossfire on?
Have been using a few other games for testing (UT3, DMC4 etc) and came to conclusion that in most cases my cpu/board appears to be the bottleneck, and the card when I use a lot of MSAA, as expected.
Was planning to upgrade to an intel crossfire board/cpu but from testing GRID it looks like it has major issues with crossfire anyway.
Anybody else have wierd issues with GRID and crossfire? Perhaps I should get a 1GB 4870 when they come out instead....but I'll probably be majorly cpu limited too. Decisions decisions.....
Freshly re-installed XP, and using Cat 8.7 drivers.
