Hello all
I regularly take my computer around in the car. Yesterday I set it back up again, for some reason it failed to boot multiple times. Eventually it did work and get through the login stage, but the performance was very slow, it seemed to run at only a few fps on the desktop. After a while it just started working again as usual. I booted it up again today and similar issues, except this time it seems to revert between normal and choppy desktop fps.
As a test I left it on the desktop, which was at this point running fine. I then ran some WebGL graphics, which slowed everything down to a crawl, including the desktop again. The FPS in the WebGL tab showed about 4 FPS, moments later performance went back to normal and I could hear the GPU fans spin up. The WebGL app was now showing normal FPS.
I was wondering whether anyone had an issue like this before? I can't see that there's any issue inside the case.
