- 2 Dec 2006
Ok then this is only a theory i was thinking of while very tired at 4am last night. So dont eat my balls or anything and listern to it first before just going down the whole :O:O:O 24hour prime or not stable thing.
Lots of people are going round saying ooo dont need quads the games dont even use all four cores. They say they dont even fully use duel cores yet.
Its true. How oftern does a Gamer use all 4 cores in a game??
So that made me think. Well C2ds are cooler then Q2ds because they use 2 cores instead of 4. But if a quad core is really only using 2 as well... why do you not stress test the temperatures on 2 cores? or perhaps 3?
It is never going to run at the heat it does when there are 4 core runing unless your using all 4 cores and you wont really be.
Was just my thinking that you could all be having higher overclocks if you stress tested it on what your using. After all, if the games you play arn't made to use 4 cores there is no way your going to be stressing the other 2 cores out much at all. Therefore your sloiwing your clocks down for no reason.
Just a thought for you guys thats all![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
