Periodic wireless performance drops?
15 Nov 2003
Marlow
I recently purchased a SqueezeBox 3 which links wirelessly to my router.
I had initial problems, but flashing the firmware to the latest version seemed to help... However, over the weeked I had a couple of periods of poor performance.
I'm baffled at why the performance seems rock solid most of the time, but then periodically it seems to go downhill.
Nothing is changing at the time when I get poor performance. I've run netstumbler and it shows no other networks around...
Any idea what else I can look at, or indeed if there's anything I can do to help?
I can't believe moving the router by a few feet will help as most of the time the connection is 100% rock solid...
Any suggestions welcome :/
EDIT - When I got home this evening the performance was terrible. I unplugged the router for a minute or so and it was then fine... Is it possible the router is misbehaving on the wireless front periodically?
