- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey up gamers!
Here are a few tasty deals for you all.
Logitech Illuminated Keyboard (920-001165) @ £54.98 inc VAT
Illuminate your typing experience – night or day – with the Logitech® Illuminated Keyboard. Bright, laser-etched, backlit keys let you type easily, even in the dark. The ultra-thin, 9.3 mm profile provides a cutting-edge design that adds an elegant touch to any desk. The PerfectStroke™ key system, with its precision micro-scissors, helps make every stroke comfortable, fluid and silent by giving you more key travel than typical notebooks keyboards. With its sleek, minimalist design, the Logitech Illuminated Keyboard delivers the ideal combination of form and function. And the soft-touch palm rest and full-size key layout help you type comfortably – even after extended use.
- Bright, laser-etched, backlit keys let you type easily – even in the dark.
- Ultra-thin, 9.3 mm profile provides a cutting-edge design that adds an elegant touch to any desk.
- PerfectStroke™ key system helps make every stroke comfortable, fluid and silent.
- Sleek, minimalist design delivers the ideal combination of form and function.
- Soft-touch palm rest and full-size key layout help you type comfortably – even after extended use.
Was £64.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Logitech K300 Compact Keyboard (920-001488) @ £13.99 inc VAT
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk – and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
- Backlit media controls
- Full-size number pad
- Space-saving design
- Ultra-flat profile
- Easy setup
Was £17.99 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
Roccat Isku Illuminated Gaming Keyboard @ £64.99 inc VAT
nonl2brThe Isku is the world’s first keyboard to feature groundbreaking Easy Shift[+]™ technology, which puts 36 easily-customizable macros in 3 spots in the easy-to-find WASD zone -- so players can give a multitude of custom orders without ever having to re-adjust the hand position.<br>
Exclusive ROCCAT™ Talk© protocol lets the Isku and other ROCCAT™ TALK- enabled products, like the ROCCAT™ Kone[+] Max Customization Gaming Mouse, talk to each other – opening up a new world of Set Bonus gaming advantages. <br>
For example, this groundbreaking tech works great with Easy Shift[+]™ technology on compatible ROCCAT™ mice, letting gamers use the Isku Easy Shift[+]™ key to activate macros for both the keyboard and mouse – offering one-stop macro activation that lets gamers concentrate more on playing and less on controls. <br>
ROCCAT™ Talk© also allows gamers to take advantage of exclusive EasyAim technology like never before. When a game demands precise marksmanship in sniper mode, a player can simply press and hold a single keyboard key and EasyAim will instantly optimize the DPI setting on the ROCCAT™ Talk©-compatible mouse. <br>
New enhanced Macro Live! Recording makes in-game macro recording a joy. Gamers simply hit the dedicated Macro Live! Recording button and the Sound Feedback tool will talk them through the quick and easy recording process. Players can program up to an amazing 500 actions for each of the 180 possible macros – giving them freedom to lay down any orders they can dream up. <br>
Backlit with ROCCAT™ Extreme Ice Blue Lighting in 6 adjustable brightness levels, the Isku makes it easy to always hit the right key -- even in low lighting. The optimized illumination also means the Isku is perfect for avoiding eye strain during those long gaming sessions. Plus, gamers can program the Isku to automatically switch its lights off if a key hasn’t been hit for a predetermined time – great for a quick break.<br><br>
- Blue key illumination with 6 brightness levels including off setting<br>
- Easy Shift[+]. for simple key duplication and activation<br>
- 3 Easy Shift[+]. zones featuring 28 easy-to-reach macro keys, including 5 doubly-programmable dedicated M-keys and 3 doubly-programmable Thumbster Keys<br>
- Macro Live! recording button for in-game macro setting; 180+ macros in 5 profiles<br>
- 8 media & hotkeys; 25+ assignable functions<br>
- Medium-height keys; optimum keystroke; advanced anti-ghosting<br>
- ROCCAT. Driver & Macro Manager, incl. macro presets for games, multimedia & office apps<br>
- Integrated Extra-Large Granulated Wrist Rest with optimized surface texture<br>
- Cable channels for better device organization<br>
- Non-slip base with lock-on keyboard feet<br>
- Fast profile switching; 5 Profile-Status LEDs<br>
- ROCCAT. Talk: Set Bonus by combining devices<br>
Was £79.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
TT eSports Challenger Pro Gaming Keyboard @ £39.98 inc VAT
Challenger Pro Gaming Keyboard will Illuminate your world and allow you to game freely.
- Red Illumination Back Light - Red illumination back light simulates the true-to-life gaming atmosphere
- 2x USB 2.0 Ports - Provide easy usage of other USB peripherals. Each USB port supports up to 100mA
- 10 Macro Keys - Program the combined action in a button to make a move ahead ofother gamers
- 6 Multimedia Keys - Instant access to multimedia function for quick audio control
- 64KB On Board Memory - Storage of up to 40 macro keys for action, shooting, RPG and strategy games
- On Board Profile Switch - On board profile switch to engage for instant game changes
- Back Light Switch - Back light switch allows gamers to choose the different levels of lighting depending on the mood
- Fan Device - Cooling fan not only keeps your hands dry and provides comfortable gaming experience
- Windows Dummy Keycaps - Enclosed with two Windows keys to disable the function; prevent from jumping out of the game by accident
- Smart Cable Management With Detachable Cable Design - Protects cable from damage of improper use. For easy storage and cable protection
Was £51.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Roccat Kone+ 6000DPI Max Customization Gaming Mouse @ £52.99 inc VAT
nonl2br
With a 6000dpi Pro-Aim Laser Sensor and its integrated Tracking & Distance Control Unit (TDCU), the further development of the prize-winning ROCCAT™ Kone Gaming Mouse has unbelievably more power under the hood. Its maximum precision and ultimate tracking are beyond comparison.
The massive upgrade made to the driver and the introduction of the EasyShift[+] button has also turned the Kone[+] into a real customizable marvel at the same time. No other mouse offers as many configuration options as the ROCCAT Kone[+].<br><br>
MAXIMUM PERFORMANCE
The revolutionary 6000dpi Pro-Aim Laser Sensor, in conjunction with its 10.5 megapixel resolution and 1000Hz polling rate, offers maximum precision, even transmitting lightning fast mouse movements with up to 30Gs of acceleration and with speeds of up to 200ips (5.08m/s) without loss or lag. Thanks to the Tracking & Distance Control Unit, which is now integrated in the laser sensor, the ROCCAT™ Kone[+] can also calculate the lift-off distance as well as fine-tune the sensor to suit the mousepad. The result: optimal tracking.<br><br>
ERGONOMIC HYBRID SHELL
The highly praised hybrid shell for right-handers, including the Soft-Touch Surface, have been retained, but really useful core improvements have been made that further increase the comfort of Kone’s successor. The mouse wheel is completely new: distinctive notch positions are perfect for gaming, and the wider design makes it easier to control. The button above the mouse wheel has been made larger and you’ll now find a nicely-sized toggle switch below the mouse wheel. The result: maximum gaming comfort.<br><br>
22 MOUSE FUNCTIONS
Thanks to the EasyShift[+] button, all the buttons – including the mouse wheel – can be assigned two functions such as macros or other functions. As a result, you now have 22 functions available at any one time instead of the usual 12.<br><br>
Find out more about EasyShift[+] and just how easy it is to use here: mehr...<br><br>
4 LED MULTICOLOR LIGHT SYSTEM
Like before, the light system remains unbeaten. Four multicolor LEDs, together with the enhanced lightpipes and configurable effects, can light up, alternate or pulsate in more than four different colors at the same time. It’s a real eye-catcher on any desktop.<br><br>
5 GAME PROFILES
You can configure your button assignments, including macros, DPI settings, the sensor sensitivity level and your lighting settings too, and save them to any one of 5 profiles on the 576kB of onboard memory. This allows you to customize your mouse to suit individual games. You can associate each profile with a particular application so the right button assignments, DPI and color settings, etc., are automatically loaded when you start the game. When a profile is set as the Windows Profile, the ROCCAT™ Kone[+] will always switch to this profile when you return to Windows after leaving a game or app. Additional profiles can be saved on your hard drive whenever you want, and then loaded to any one of the 5 profile slots using the driver menu.<br><br>
MACRO MANAGER
Creating and editing your own command sequences is made easy thanks to the highly praised Macro Manager. Predefined macro presets for the top 20 PC games as well as several office apps make it even easier to customize the mouse – plus the new Loop Function now makes it possible to loop macros indefinitely.<br><br>
SOUND FEEDBACK
The famous ROCCAT voice gives immediate feedback when you change DPI settings, profiles, the volume level or sensitivity setting. As you don’t need to look at an additional display on the screen or on the mouse itself, nothing will distract from the gameplay. It really is as easy at that.<br><br>
CUSTOMIZE THE WEIGHT
A weight system comprising 4 x 5g weights is included, allowing you to customize the weight in four stages to suit your preferences.<br><br>
Was £62.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
Razer DeathAdder Respawn 3500 DPI Xtreme Precision Gaming Mouse - Retail @ £42.98 inc VAT
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
- 3500dpi Razer Precision™ 3.5G infrared sensor
- Ergonomic right-handed design
- 1000Hz Ultrapolling™ / 1ms response
- Five independently programmable Hyperesponse™ buttons
- On-The-Fly Sensitivity™ adjustment
- Always-On™ mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60–120 inches per second and 15g of acceleration
- Zero-acoustic Ultraslick™ Teflon feet
- Gold-plated USB connector
- Seven-Foot, lightweight, braided fiber cable
- Approximate size: 128mm (length) x 70mm (width) x 42.5mm (height)
Was £59.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
Microsoft Wireless Keyboard 6000 - Retail (J9C-00002) @ £14.99 inc VAT
Grace your workspace with the subtle elegance of Windows Aero, bought to you in the format of the Wireless Keyboard 6000. Giving you 5 customisable keys allowing you to set hot keys for your most commonly used folders, files and webpages. There are also media keys allowing you to control your music with a single key press.
- Wireless
- Thin, Translucent Border Inspired by Windows Aero
- Comfort Curve with Quiet Touch Keys
- Flip 3D
- My Favourite Keys
- Media Keys
- Battery Status Indicator
Was £21.99 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Overclockers UK Official Elite Gaming Mug @ £4.99 inc VAT
Introducing the Overclockers UK Official Mug:
'The Ultimate Desktop Peripheral'
Designed and engineered for maximum 'Hot Drink Holding' performance. The Overclockers UK Official Mug leads the way in the fight against thirst.
Desk Mountable for increased stability, the Overclockers UK Official Mug allows you to safely hold hot beverages with its large, ergonomic, easy to hold handle.
Featuring striking graphics on both sides of the Mug, friends and co-workers will know you mean business. It doesn't matter if you are a serious gamer or an overclocking guru, the Overclockers UK Official Mug takes the capabilities of the mug to a whole new level.
A triumph in design, you will never grace your desk with a more capable item.
Developed in conjunction with expert technical staff and overclocking experts, the OcUK mug gives the end user the edge no matter what the scenario
Technical Specification:
• Sleek Black design
• Wide tapered rim for dribble free operation
• Heavy Duty build quality to withstand the hottest beverage
• Unparalleled 'Hot Drink Holding' ability
• Ergonomic Handle Design
• Overclockers UK Logo on both sides
• Available in right and left handed configurations
• Unique 'Mug & Play' features
• Compatible with a wide range of hardware configurations
Only £4.99 inc VAT.
ORDER NOW
Was £64.99 Inc. VAT
ORDER NOW
- Easy setup
Was £17.99 Inc. VAT
ORDER NOW
Was £79.99 Inc. VAT
ORDER NOW
Was £51.99 Inc. VAT
ORDER NOW
nonl2br
MAXIMUM PERFORMANCE
22 MOUSE FUNCTIONS
5 GAME PROFILES
MACRO MANAGER
SOUND FEEDBACK
Was £62.99 Inc. VAT
ORDER NOW
- Always-On™ mode
Was £59.99 Inc. VAT
ORDER NOW
- Wireless
- Flip 3D
- My Favourite Keys
- Media Keys
Was £21.99 Inc. VAT
ORDER NOW
Only £4.99 inc VAT.
ORDER NOW
