Perl Help - Use of uninitialised values
12 Jan 2006
I have no idea what to try, i have traced the problem to the like
process_log($line);
But have no idea how to fix it as i declare $line before hand :s
The error i get is:
Code:
Use of uninitialized value $sessionState in string eq at parser2.pl line 124.
    main::process_log('Dec 16 07:50:22 vpn-klb-prv 1765156 12/16/2007 07:50:21.110 S...') called at parser2.pl line 54
Use of uninitialized value in string eq at parser2.pl line 130.
so on and so forth..
Code:
#!/usr/bin/perl -w
                  #-w use warnings
                  #-T use Taint to ensure program is secure
#use strict 'vars';                     #Force variable declarations
# Functions to locate errors
use Carp ();
local $SIG{__WARN__} = \&Carp::cluck;
#=== Delcare Varibles ===#
my $line = "empty";             #Line to be processed
my $file = 'testLog.txt';       #Path to log file
my @log = ();                        #Stores lines from log file
# Session Data Array as global (to avoid un-neccesary processing when passed into function)
our @sessions = (
    # Session Data Holding Variables
    {'clientIPAddress' => 'null',    #Address assigned from IP pool
     'currentCode' => 'Initialiser', #Current IKE code being processed
     'connectDate' => 'null',        #Date of connection to access point
     'connectTime' => 'null',        #Time of connection to access point
     'userID' => 'null',             #Username unique to user
     'authenticationTime' => 'null', #Time user's has been authenticated
     'groupID' => 'null',            #VPN group user belongs to (usually Roamnet)
     'platformType' => 'null',       #Platform user is running Windows, Unix etc..
     'clientVersion' => 'null',      #Version of VPN client
     'vpnPoolAddress' => 'null',     #IP address assigned from VPN pool
     'disconnectTime' => 'null',     #Time session was disconnected
     'duration' => 'null',           #Duration of session
     'bytesTx' => 'null',            #Bytes Transmitted
     'bytesRx' => 'null',            #Bytes Recieved
     'reasonForDisconnect' => 'null',#Reason for connection termination
     'errorMessages' => 'null',      #Additional error messages
     'state' => 'Disconnected'       #State of session
#=== Get data from file ===
open(LOG, $file) or die "Log file not found";    #Open file under the handle LOG
@log=<LOG>;          #Read file into @log
close(LOG);          #Close the log file
foreach (@log) {
 $line = $_;
  if($line eq 'empty'){                            #Check to see if line is empty
      print 'Warning Line is Empty <BR>\n';
  }else{
  #===Process line ===
  chomp($line);       #Removes new line character from entry
  process_log($line);                    #Call function to precess log line <--------- line 54
line 124
Code:
sub process_log { #Script to parse logs
 #== Parameters passed into function ==
 #$line (@_) line being processed
 #== Declare Variables ==
 my $currentCode = 'null';                          #Code being processed
 my $currentIP = 'null';                            #IP of line being processed
 my $currentUserID = 'null';                        #UserID of line being processed
 my $numberOfSessions = 'null';                     #Number of sessions in the array
 my $data = 'null';                                 #Stores result of regex expressions
 my $currentLine = 'null';                          #Whole Line currently being processed
 my @sepearatedLine = ();                                #Seperated line
 my $sessionExists = 'false';                       #Boolean check for Does session exist
 #=== Store elements from line ===
 $currentLine = shift;                              #Get line passed into function
 @seperatedLine = split(/\s/, $currentLine);        #Split line based on empty space delimitation
 $currentLine =~ m/SEV=\d (.*) RPT/;                #Extract current code from line
 $currentCode = $1;                                 #Get current code
 $currentIP = $seperatedLine[10];                   #Get IP from line
 $numberOfSessions = scalar (@sessions);            #Get number of elements sessions array
 # IKE/DBG64
 if ($currentCode eq 'IKEDBG/64'){
      for (my $i=1; $i <= $numberOfSessions; $i++){               #Check to see if session already exists
        my $sessionIP = $sessions[$i]{"clientIPAddress"};         #Get IP for selected session
        if ($currentIP eq $sessionIP){                            #Compare IP
        #-Session Exists-
          $sessionExists = 'true';
          #Check for illegal connections (session not terminated correctly)
          my $sessionState = $sessions[$i]{"state"};              #Get current state of session
                    if ($sessionState eq 'Disconnected'){         <---------------------------------- line 124
           #--Legal Session--
           $sessions[$i]{"state"} = 'Connecting';                 #Progress state to connecting
           last;                                                  #Break out of loop
           }else{
           #--Illegal Session--
           if ($sessions[$i]{"errorMessages"} eq 'null'){            #Check if there are any error messages
             $sessions[$i]{"errorMessages"} = 'Errors: ';            #Add title
           #Error Message
           $sessions[$i]{"reasonForDisconnect"} = 'Session was not teminated correctly and has been termintated by parser';
           save_session($i);                                       #Call save_session function
           splice(@sessions,$i,1);                                 #Delete the current session
           #Create new session
           create_new_session($i);
           $sessions[$i]{"clientIPAddress"} = $seperatedLine[10];  #Used as key for session
           $sessions[$i]{'currentCode'} = $currentCode;            #Store current code for debugging
           $sessions[$i]{"connectDate"} = $seperatedLine[5];
           $sessions[$i]{"connectTime"} = $seperatedLine[6];
      if ($sessionExists eq 'false') {
        #-Session doesn't exist-
          #Create new session
          create_new_session($numberOfSessions);                                 #As the array starts from 0, $numberOfSessions will
        #always be greater than the index for the last session.
          $sessions[$numberOfSessions]{"clientIPAddress"} =  $seperatedLine[10]; #Used as key for session
          $sessions[$numberOfSessions]{'currentCode'} = $currentCode;            #Store current code
          $sessions[$numberOfSessions]{"connectDate"} = $seperatedLine[5];
          $sessions[$numberOfSessions]{"connectTime"} = $seperatedLine[6];
function create_new_session
Code:
sub create_new_session {            #Script to create a blank session
 my $sessionID = shift;                                  #Session ID
 # Create empty session
 $sessions[$sessionID]{'clientIPAddress'} = 'null';    #Address assigned from IP pool
 $sessions[$sessionID]{'currentCode'} = 'null';        #Current IKE code being processed
 $sessions[$sessionID]{'connectDate'} = 'null';        #Date of connection to access point
 $sessions[$sessionID]{'connectTime'} = 'null';        #Time of connection to access point
 $sessions[$sessionID]{'userID'} = 'null';             #Username unique to user
 $sessions[$sessionID]{'authenticationDate'} = 'null'; #Date user's has been authenticated
 $sessions[$sessionID]{'authenticationTime'} = 'null'; #Time user's has been authenticated
 $sessions[$sessionID]{'groupID'} = 'null';            #VPN group user belongs to (usually Roamnet)
 $sessions[$sessionID]{'platformType'} = 'null';       #Platform user is running Windows, Unix etc..
 $sessions[$sessionID]{'clientVersion'} = 'null';      #Version of VPN client
 $sessions[$sessionID]{'vpnPoolAddress'} = 'null';     #IP address assigned from VPN pool
 $sessions[$sessionID]{'disconnectTime'} = 'null';     #Time session was disconnected
 $sessions[$sessionID]{'duration'} = 'null';           #Duration of session
 $sessions[$sessionID]{'bytesTx'} = 'null';            #Bytes Transmitted
 $sessions[$sessionID]{'bytesRx'} = 'null';            #Bytes Recieved
 $sessions[$sessionID]{'reasonForDisconnect'} = 'null';#Reason for connection termination
 $sessions[$sessionID]{'errorMessages'} = 'null';      #Additional error messages
 $sessions[$sessionID]{'state'} = 'Disconnected';      #State of session
} #End Create empty session
Any help would be much appreciated as i am out of ideas
