Perl Help
25 Nov 2004
Manchester Uk
I'm a complete beginner at programming, so any technical replies may go straight over my head. I put to get a script that took some variables from a csv file and output this to some files. A shortened version is;
#!/usr/bin/perl
use strict;
use warnings;
use Text::CSV;
my $file = 'routerdetails.csv';
my $csv = Text::CSV->new();
open (CSV, "<", $file) or die $!;
while (<CSV>) {
next if ($. == 1);
if ($csv->parse($_)) {
my @columns = $csv->fields();
open (MYOUTFILE, ">>001--$columns[0]--877-orderno--autoconfig.txt");
print MYOUTFILE "hostname $columns[0]\n";
print MYOUTFILE "!\n";
print MYOUTFILE "boot-start-marker\n";
print MYOUTFILE "boot-end-marker\n";
print MYOUTFILE "logging buffered 51200 warnings\n";
print MYOUTFILE "enable secret $columns[8]\n";
print MYOUTFILE "aaa new-model\n";
print MYOUTFILE "end\n";
close(MYOUTFILE);
} else {
my $err = $csv->error_input;
print MYOUTFILE "Failed to parse line: $err";
close CSV;
This works fine, but the full version has a lot of print lines for the configuration is it outputting. I've been trying to figure out how I can have a separate text file with the configuration, inport it, swap out the csv file variable and output it as a bunch of files.
My latest attempt (which doesn't work) is;
#!/usr/bin/perl -w
use strict;
use warnings;
use Text::CSV;
my $infile = '877.txt';
while (<CSV>) {
next if ($. == 1);
open IN, "< $infile" or die "Can't open $infile : $!";
open OUT, ">001-$columns[0]-877-orderno-autoconfig.txt";
print OUT <IN>;
close IN;
close OUT;
} else {
print OUT "Failed to parse line: $err";
close CSV;
This does import the file, but doesn't swap out the variables from the csv file. Can anyone point me in the direction of the correct way to do this?
