Permission denied - echo to file
1 Mar 2003
Cotham, Bristol
I have a script (which I can't change) that has something like the following in it
echo "echo to file" >> /home/bob/bob.txt
/home/bob has 777 permissions set, so if I'm logged in as paul I can cd to /home/bob and successfully "touch bob.txt" (snigger), I can't however do the above. Why? Remembering I can't change the script
Is the file already in use by another process? (IIRC touch without parameters only simulates an update to the file and doesn't actually modify it).
