CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:24:51 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: SERVER
OS version: Windows 10 , 10.0, build: 15063 (x64)
Hardware: Z97X-Gaming 7, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 16233 MB total
CPU SPEED
Reported CPU speed: 40 MHz
Measured CPU speed: 1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 6883.338573
Average measured interrupt to process latency (µs): 2.021638
Highest measured interrupt to DPC latency (µs): 6881.034569
Average measured interrupt to DPC latency (µs): 0.610369
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 126.490
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.053949
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.081536
ISR count (execution time <250 µs): 1698701
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 314.09550
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 388.13 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.032774
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 388.13 , NVIDIA Corporation
Total time spent in DPCs (%) 0.113559
DPC count (execution time <250 µs): 6525639
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 21
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 37.682694
CPU 0 ISR highest execution time (µs): 126.490
CPU 0 ISR total execution time (s): 9.684103
CPU 0 ISR count: 1691848
CPU 0 DPC highest execution time (µs): 300.136750
CPU 0 DPC total execution time (s): 10.459288
CPU 0 DPC count: 5765678
CPU 1 Interrupt cycle time (s): 18.060617
CPU 1 ISR highest execution time (µs): 97.052250
CPU 1 ISR total execution time (s): 0.040748
CPU 1 ISR count: 6627
CPU 1 DPC highest execution time (µs): 314.09550
CPU 1 DPC total execution time (s): 0.324858
CPU 1 DPC count: 62844
CPU 2 Interrupt cycle time (s): 13.190399
CPU 2 ISR highest execution time (µs): 55.8670
CPU 2 ISR total execution time (s): 0.000823
CPU 2 ISR count: 209
CPU 2 DPC highest execution time (µs): 232.737750
CPU 2 DPC total execution time (s): 0.835328
CPU 2 DPC count: 192173
CPU 3 Interrupt cycle time (s): 16.603643
CPU 3 ISR highest execution time (µs): 7.416250
CPU 3 ISR total execution time (s): 0.000068
CPU 3 ISR count: 17
CPU 3 DPC highest execution time (µs): 134.49550
CPU 3 DPC total execution time (s): 0.346544
CPU 3 DPC count: 84074
CPU 4 Interrupt cycle time (s): 13.569195
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 140.587750
CPU 4 DPC total execution time (s): 0.522430
CPU 4 DPC count: 158121
CPU 5 Interrupt cycle time (s): 16.859769
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 111.74850
CPU 5 DPC total execution time (s): 0.271296
CPU 5 DPC count: 57421
CPU 6 Interrupt cycle time (s): 12.910850
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 145.853750
CPU 6 DPC total execution time (s): 0.546212
CPU 6 DPC count: 155089
CPU 7 Interrupt cycle time (s): 16.697989
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 114.327750
CPU 7 DPC total execution time (s): 0.239516
CPU 7 DPC count: 50260
