Personal DNA Quizzer
17 Nov 2004
The Republic
Little quiz I got sent at lunch time
http://www.personaldna.com
You are a Benevolent Inventor
You are an Inventor
Your imagination, self-reliance, openness to new things, and appreciation for utility combine to make you an INVENTOR.
You have the confidence to make your visions into reality, and you are willing to consider many alternatives to get that done.
The full spectrum of possibilities in the world intrigues you—you're not limited by pre-conceived notions of how things should be.
Problem-solving is a specialty of yours, owing to your persistence, curiosity, and understanding of how things work.
Your vision allows you to identify what's missing from a given situation, and your creativity allows you to fill in the gaps.
Your awareness of how things function gives you the ability to come up with new uses for common objects.
It is more interesting for you to pursue excitement than it is to get caught up in a routine.
Although understanding details is not difficult for you, you specialize in seeing the bigger picture and don't get caught up in specifics.
You tend to more proactive than reactive—you don't just wait for things to come to you.
If you want to be different:
Try applying your creativity to more artistic arenas, and letting your imagination take less practical forms.
how you relate to others
You are Benevolent
You are a great person to interact with—understanding, giving, and trusting—in a word, BENEVOLENT
You don't mind being in social situations, as you feel comfortable enough with people to be yourself.
Your caring nature goes beyond a basic concern: you take the time to understand the nuances of people's situations before passing any sort of judgment.
You're a good listener, and even better at offering advice.
You're concerned with others at both an individual and societal level—you sympathize with the plights of troubled groups, and you can care about people you've never met.
Considering many different perspectives is something at which you excel, and you appreciate that quality in others.
Other people's feelings are important to you, and you're good at mediating disputes.
Because of your understanding and patience, you tend to bring out the best in people.
You spend a lot of time taking care of others, but don't forget to take care of yourself!
Sometimes you can get overcommitted, and when you sacrifice spending time with those close to you, it can make them feel unimportant.
Seems to give pretty accurate results
Hmmm turn's out I'm a Dynamic Analist my lowest score was 2 for Empathy and the highest was 94 for both Masculinity and Earthy/Imaginative sweet :D but overall it did seem quite acurate.
The question seem to steer me away from my actual reactions to situations, I don't always react consistanty. Overall not too bad, came back as generous leader. With lowest scores being trust, and feminity, the rest are all fairly high.
Same.
I find these tests rather a waste of time and not necessarily a good idea as a lot of people read a lot into them.
If you answer quickly and honestly, then it should give an accurate picture of you, which is hardly surprising as you're busy telling it all about you.
i am a Respectful Idealist which aint bad in my opinion
thought this test was pretty good, much better than a lot of the online rubbish i do while bored at work (idealising about things respectfully naturally :) )
