Perspex Wizards?
18 Oct 2002
Pentonville Prison
I have decided I'd like to stack my Raspberry Pis, joining them with plastic hex bolts, so the only things that need protecting are possibly the bottom of the stack and definitely the top. I cannot seem to find a plain rectangle with holes in corners (they all seem to want to add "fingers" to the corners).
Does anyone know somewhere I can get perspex cut/drilled cheap?
For perspex cut to size I would try ebay, many of the sellers there usually offer custom size quotes. Not sure on the drilling though, do you not have a drill or know someone who can lend you one?
Have a look at Sheetplastics.co.uk, they got recommended in the recent Custom PC magazine and look to sell lots of various plastic, in custom sizes and will do screw holes and similar. Looks like they'd be able to do what you are after!
