24 Sep 2006 at 12:59 #1 sanofi sanofi Associate Joined 9 Jul 2006 Posts 1,848 Location Vienna Running PES 5 via 360 on my Dell 2007wfp. When the game runs it runs in a window in the centre of the screen, on all aspect ratios. Is this normal? Can it be made full screen or does the game played via BC on the 360 cause this?
24 Sep 2006 at 13:05 #2 NokkonWud NokkonWud Caporegime Joined 1 Oct 2004 Posts 26,315 Location Redcar It's normal, the game's made to run in a 4:3 aspect ratio and as a result, it becomes fixed at 4:3.
24 Sep 2006 at 13:20 #3 Steve09 Steve09 Soldato Joined 19 Jul 2006 Posts 2,967 Location Leicester Thats why you should stick to a 15" monitor lol Like me
24 Sep 2006 at 13:42 #4 sanofi sanofi Associate OP Joined 9 Jul 2006 Posts 1,848 Location Vienna Ah I see, will this be the same for other games played via BC?
24 Sep 2006 at 16:16 #5 Meeko Meeko Associate Joined 3 Apr 2003 Posts 442 Location Dunfermline Set the screen resolution to 480p in the dashboard before you play PES and you'll get an almost full screen pic.
24 Sep 2006 at 16:45 #6 Energize Energize Caporegime Joined 12 Mar 2004 Posts 29,960 Location England sanofi said: Ah I see, will this be the same for other games played via BC? Click to expand... No idea what bc is supposed to be. But if you play a game thats in a 4:3 aspect ratio then you will get black bars at the side of the picture.
24 Sep 2006 at 17:42 #7 PiKe PiKe Caporegime Joined 18 Oct 2002 Posts 25,295 Location Lake District BC = Backwards Compatibility.
25 Sep 2006 at 15:30 #8 sanofi sanofi Associate OP Joined 9 Jul 2006 Posts 1,848 Location Vienna Meeko said: Set the screen resolution to 480p in the dashboard before you play PES and you'll get an almost full screen pic. Click to expand... Thanks Meeko, I'll give that a try.
