Pes2008 resolution fix is here!
13 Aug 2007
Wide Ness
Apologies if you guys are already on to this or if it has already been posted. I'm finally able to play the game at my native resolution! Hope it helps those who are looking for it.
Download the file from here http://www.megaupload.com/?d=3Z5BDRW2 or here http://www.speedyshare.com/989168582.html
The files contained are:
1152settings.exe = 1152×864 (800400006003)
1360settings.exe = 1360×768 (500500000003)
1440settings.exe = 1440×900 (A00500008403)
1680settings.exe = 1680×1050 (900600001A04)
Game now plays at just the right speed for me at 1440x900 :)
get the proper res fix in the latest kitserver thats an old fix which isnt really a proper fix
I get pes2008.exe is an unknown file when trying to install the latest kitserver! Is version 700f the correct one? I would prefer to get this installed tbh.
701 is the latest one. 700f only works before the patch from konami
Have sorted this now, thx. Really am falling in love with this game now i'm able to play it as it should be.
Does anyone know if this game is locked at 60fps? I'm running 8800gt and Fraps stays at constant 60!
