PES6 on 360
27 Sep 2005
Burbage, Hinckley
I already have PES6 on PC and PSP, but I was considering getting it on the 360 as well. Does it offer any other imporvements over PC version other than graphics?
Can you get updated teams and kits etc like you usually can with the other versions?
Nope. If your happy with the pc version stick with it. Unless you want to play over live.
how much better are the graphics over the PC version though? I have played the demo but you dont really get a good enough look at just how good it is from a single match imo.
I dont think the gfx are anything to write how about. Its about the gameplay. Which you will have on the pc version anyway. I like the ease of pad and ease of playing my friends so I got the 360 version.
If your happy with the pc version I wouldn't send more money. Graphically there aint a lot in it. Of course if you going to play on the HD TV and your friends when they come over, the 360 version is easier and more socialble.
hmm... I might just stick to the PC version. Tbh I'm dissapointed they stuck with the last gen graphics on PC but upgraded for the 360. I think my main hurdle for playing on 360 will be the controller, which is fine for playing a new game, but when you have played every incarnation of PES of a PS controller it's just gonna be a bit tricky to get used to. I have a Logitech rumblepad 2 for the PC which is just the same as a PS controller, I wonder if it will work with the 360? I tried it with the PS3 and it worked fine!
The 360 graphics are still pretty poor.
While nothing will ever come close to the PS controller for pro evo, you do get used to the 360 pad after a while, does take some effort though.
Unless you really want to play over xbl, I would wait for pro evo 7 tbh.
