PES6 - Stuttering at kickoff
if youre using a nvidea card set the vsync to on not off or auto must be set to on
you do get a little stutter in the game at start but by half time its normally gone
If its the stutter you get like I had on the x1950pro there is no other way.... it runs at 60fps and doesn't drop a frame ever.
Its ridiculous I bought it and it works with a technically illegal patch... go figure
