PETG Tubing ......a Problem?
7 Mar 2017
essex
Newbie here.....first pc build in @15 years and first water cooled build ever.
Im almost ready tu cut and bend pipe but now Im worried as to what coolant i should use as ive seen lots of conflicting info on the web....(information overload) regarding hardening and staining the tubing etc
List of loop parts:
EK Water Blocks EK-Velocity RGB - Full Nickel
Barrow PETG Tubing 14 mm x 500mn
Phobya G-Changer 240 V2 Full copper radiator
AlphaCool Ice Block Aurora Plexi GPX-N RTX 2070 Super Windforce (GFX Card Cooling Block)
Phanteks Glacier D140 Distribution plate
Alphacool Eisfluegel Flow Indicator - Acetel
Matercool Heatkiller Resovoir for D% pump
Aqua Computer D5 NEXT RGB Smart pump
Various XSPC G1/4/14mm Triple seal rigid tube fittings
cheers
Mayhems X1 pre-mix will be fine with that tubing. I use Mizucool (Ebay seller) 14mm PETG tubing with Mayhems X1 red and have had no problems. I did a strip down a couple of months ago and the X1 red didn't stain anything at all, the tubing and blocks looked like new. You don't have to worry about additives either as X1 has everything you need already in it.
