Petrol or Diesel?
Status
Not open for further replies.
24 Jul 2004
Devon, UK
I've finally got some money together for a car. Which car isn't important right now - i'm going to look at some over the next few weeks.
What I can't come to a decision over is the old chestnut of getting a petrol or diesel car. I currently drive a diesel and I find it fine, but this will be my own car, so i'm going to make my own decision. :)
Standard issue responses of "it's smelly, it's noisy, it's gay" etc. will just be ignored. I want to hear people's honest opinions of this.
Thanks.
*finds safe cover and dons flame retardant suit*
How many miles a year you do will be the main question asked so provide this and what your budget of car is and we can give you some answers.
Petrol for me everytime though.
Basically, although I don't want recommendations as i'm going to try a few and form opinions, i'm looking at £6-7K and it's going to be doing 15-20K a year.
I want a hatchback only, and it needs 5 doors. And not be French. I'll test drive the usual suspects (Focus, Golf, Leon, Civic, Fabia, maybe A3?) and see what takes my fancy. Basically I don't have any rush to get this bought.
Can I ask how you arrive at the figure of 20K miles/year?
I really dont think the argument of 20k upwards for diesel holds up to many people.
That 20k figure would only work if you came here saying "I want a 2006 VW Golf GT sport with approx 30k miles" - because then you'd be spending more to get the same car in diesel form.
As I've tried to explain before, to some people the lower daily running costs is worth more than a lower mileage, a different number on the plate or a few gadgets...
For 15-20k a year I'd definitely be getting a diesel, out of the list I'd say Focus or Leon. Golf is good but might be a bit on the pricey side. Have you considered something bigger - Mondeo, Passat etc?
[TW]Fox;14055069 said:
Well do the maths then. Work out how much it costs in petrol to do 20k miles and how much it costs in diesel, then see if the saving offsets the higher purchase costs and the horrible noise from the diesel.
Well obviously it depends totally on what I get.
However as regards purchase costs, is this still the same for used cars?
Also, how do you put a price on noise? :p
It never ceases to amaze me how people DONT get this.
Sure, you dont decide to buy a 2006 Golf GT TDI with 30k on the clock. You decide to spend £10k. But if a 2006 Golf petrol of the same spec/performance (I know VW petrol engines are crap but for the sake of argument pretend not) is actually only £9k, you get £1k change to spend on running costs.
How is that difficult to get your head around?
Just because you have a budget doesn't mean you must spend all of it, especially if you can get a car of the same age, condition, spec and mileage just with a different engine for less money.
Considered them yes. Not a fan of the Passat at all. The Mondeo is a really nice car, nowt wrong with it but I prefer the looks of the Focus (and many of the other hatchbacks).
I get it completely, but my point has always been that people dont actually buy cars like that generally. Are you actually suggesting he spends £6k instead of £7, puts £1k in a savings account and transfers out the difference in cost in order to offset it?
I understand your point of view but I accept you dont understand mine - many people (including the OP I'm sure) do....
Right, i'm actually grasping it. You only needed to explain. :)
Out of interest Fox, are there ANY diesels you would consider recommending?
Status
