I changed my spark plugs around a week and soon after when I switched the engine on there was a very strong smell of petrol which is still persisting. Hard to say if its just at idle or not as you can't smell it on the go as it will just get absorbed in the air whilst on the move, but it is there when idle.
Could the spark plug change have caused any of this?
I did have some trouble fitting the last two as they didn't seem to hand screw in as many turns as the others, but I torqued them and seemed fine and the car is running a little smoother, so no issues with performance or any funny noises.
Cheers for any pointers or suggestions.
