Just thought I'd bounce my thoughts off a few people..
My girlfriend's 207 (with the old god-awful 1.4 8v 75bhp engine) has always had a bit of an issue where if you go to start it, it won't run unless you apply a bit of throttle when cranking.
It annoys her but the throttle workaround always works and once started, the car drives fine.
Today, after I'd finished fitting her new wing mirror, out of pure curiosity I tried unplugging a couple of sensors in the engine bay to see if either of them made a difference to how it started and ran. O2 sensor = no difference. MAP sensor, however, when unplugged, caused the car to start perfectly. I didn't drive it but it started and idled absolutely fine. I turned it off and on a few times and it was perfect. I then plugged the sensor back in and it was back to its usual tricks.
A new MAP sensor is £13. Is this the likely cause? I'm happy to give it a go for the sake of £13 unless someone more learned than me says it's not going to do bugger all and it's a coincidence or there's a technical reason that doesn't affect starting.. Or whatever.
Thanks!
Thanks!
I guess a little more stripping down is in order at some point.
