PH-F120SK 120MM FAN where to connect
JRAINBOW should be the right ones according to the manual. Just check the JRAINBOW pins are 3 pin with the DRGB connector on the fans. It'll either work or it wont.
Install dragon centre software to control the lighting effects if they do work.
I got the fans and the RGB running but I can not change the color in mystic lights. All they are doing is the rainbow effect. They are connected to JRAINBOW 3pin bios is on auto should I change it to pwm. Cheers
I don't think you can control the DRGB in the motherboard bios. Fan speed is what the bios is detecting.
Have you connected the DRGB lead on the fans to the Jrainbow header on the board the right way round? Easy mistake to make & can be overlooked.
