Phantek Enthoo Evolv & LED strips
21 May 2008
Lincs
I bought this case and installed everything in it and then decided i needed to stick some LED's in it as it was too dark to see it's inards!!
As it's a Phantek case I bought a Phantek 1m LED strip: https://www.overclockers.co.uk/phanteks-multicolor-magnetic-rgb-led-strip-1-metre-ca-006-pt.html
The case has a cable to attach the strip to too but when i connect it nothing happens! Pressing the button on the front of the case (as per the case guide) also does nothing.
Have I missed something that needs to be done to get the strips to work or have a got either a dud case wire or dodgy LED strip?
