- 19 Feb 2011
Hi Guys,
This product comes with the XPSC 750 Bay Res and a 360 Rad etc, i plan on putting an i7 4770k under the cpu block, however i just bought a 290 from your fine selves, am i right in thinking the 360 rad will need an additional 240 rad to keep the 290 cool as well? and obviously a GPU block.
Also will the pump in the XSPC 750 Bay Res have enough grunt to push the flow around a 360 + 240 Rad + CPU and GPU Blocks?
Lastly any advice on loop configuration when adding the other Rad and GPU block if required?
Thanks guys
Thanks guys
