Phantek Evolv Shift 2 - Full custom loop
17 Apr 2022
Skipton
Hey,
I’ve always loved the Phanteks Evolv cases with the tempered glass panels, truly a beautiful case but I’m sure most would agree that the layout design is atrocious. Its one of the most attractive cases but on the flip side one of the most challenging cases to build in. As standard, you’ve little to no chance of building a somewhat powerful system thats aircooled and not see temps hitting a scorching 85-95c with the side panels on.
My first build in this case had a 9600k cooled with a corsair h60i AIO and an air cooled 2070 super and on good days, the GPU would hit 85c in a few minutes of intensive gaming. A complete disaster of a setup and so loud it made headphones a must.
So, with the release of the revised model, the Evolv Shift 2, I set about figuring a way to build a 2k/4k gaming rig that was both silent and couldn’t fry an egg on the GPU
Fast forward a few months and, although its still a work in progress, I’d say I’ve finally made that dream a reality.
Specs:
  • ASUS Rog Strix B550i motherboard
  • Ryzen 5600X (stable undervolt of -30) with EK Velocity waterblock
  • ASUS TUF RTX3080 12gb OC (stable undervolt) with EK Quantum Vector waterblock + backplate
  • 32Gb Corsair 3600mhz DDR4
  • 1tb WD Black SN850
  • Corsair SF750 platinum PSU
  • 1x 240mm XSPC Ultrathin rad (nestled between the back panel and the chassis)
  • 2x Noctua NF-A12s cooling the 240mm rad
  • 1x 140mm Corsair rad
  • 1x Noctua NF-F14 cooling ghe 140mm rad
  • EK XTOP DDC pump
  • 13mm EK Duraclear tubing
  • EK Solid Azure Blue coolant
Yes, granted, there’s no reservoir. The pump placement is a bit skewiff as its edged out to prevent stress on the GPU block. But these are still works in progress. If anyone has any recommendations of an ultrasmall form factor reservoir and pump I’d welcome any help
So, how was this achieved? One word, ‘DREMEL’ . In order to fit the two 120mm fans, the centre pillar needed dremel’ing out. As well as a significant amount of the back part of the chassis. It also needed heavy modification to the bottom plastic ‘stand’, which was cut out to allow the 140mm corsair rad and noctua 140mm fan to sit at the bottom. I tried hardline tubing in this thing but after tearing my hair out, I abandoned it and opted for soft tubing instead.
Then, its simply a matter of chucking it all in and bobs your uncle
So, the real question. How does this baby perform? Was it all worth it?… … … Hell yes.
A three hour stress test showed temperature saturation of max Coolant 49c / CPU 54c / GPU 58c. This is all with the DDC pump set at a constant 20%, and fan curves optimised so even under the heaviest of workloads, there’s barely a whisper from the fans. I’m genuinely surprised how quiet this thing truly is.
Hope you all enjoy, any questions let me know and I welcome any suggestions of criticism ofc
just defeets the point of ITX?
Depends, I've seen wall mounted rads, rads attached to bottom of desk etc. Means quick disconnects, and possibly some holes but frees up a lot of space internally and provides better heat management.
A nicely mounted external rad certainly helps with the original Evolv's airflow/heat issues...but it does entirely come down to whether the slightly larger footprint is acceptable. It's not looking like it "necessary" as the doors shut and it didn't melt! That said, I think the coolant max temp in that torture test is pushing it beyond the rated limit for some of the components (pump tubing etc) and with no res, you may find the pressure goes up with a detrimental effect on the O-ring sealing the GPU; it can start to weep and drip on things you don't eant dripped on.
Where to stick a res? Presumably you have a stop plug in the rear of the top GPU port? Is there enough room for a 90° and then a small res in the space above? Depending on space and budget, something like a small tube res or one of the flat type like the Phanteks Glacier 120ml or the Ek Quantum 120ml
One of these on the top would sort out any over-pressure issues too. Needs to have air below it rather than the coolant touching it... but if mounted horizontally, you can always run a 90° up off a port and then mount it.
