Phantek RGB Starter kit
8 Dec 2012
Hi all,
has anyone used this kit and able to say whether the cabling that comes with it allows you to put (for example) a strip at the top of the case and a strip at the bottom or can you only daisy chain them onto the end of the other one.
My basket at Overclockers UK:
Total: £23.89 (includes shipping: £9.90)​
or would i need to do it this way and get a strip that will go all the way around, 1m should be enough for a full circle around my s340 elite.
Total: £27.64 (includes shipping: £8.70)​
You can do them as separate strips but they'd still need to join up somewhere, unless your RGB hub has additional sockets.
(you can even do them as separate strips & join them manually if you're comfortable soldering & have 18 AWG wire - they have 12V, and R/G/B channels)
Check the third picture in the store - You want that but longer?
I'm pretty sure the starter kit comes with an extension cable that will be long enough to allow a strip at the top and one at the bottom.
I had the same kit and did the same as what you want to do in my Phanteks P400s case
I ended up getting the corsair strips with node pro. Software is abit fiddly but ive managed to get it glowing nicely :)
I tried and failed with the Node Pro so ended up getting the Phanteks digital RGB starter set.
Like you I am too glowing nicely :)
We're going to need pics :D
just need a nice 11 series GPU now :p
I know this topic is a bit old but I’ve been picking bits up for my new pc build.
In maplin I picked up this NZXT hue starter kit with box and two fans for £24. Worth it for that price.
