Phanteks Amp PSU - 12V-2×6 Cable Issue
26 Mar 2026
United Kingdom
Hi all,
A little confused at the moment. After receiving my new GPU, I found the cable from my up to date PSU that has the newest revision 12V-2×6 cable and it says "600w" printed in white, at both ends/connectors. No specified instructions seem to be present in terms of which pin outs go to the card and the PSU. Any suggestions? Or is this a non issue, meaning I can plug the cable in either way?
Any help would be most appreciated.
If its the same 12V-2x6 connector on the PSU then it probably works fine both ways, especially if there are no instructions saying otherwise.
The connector is the same on both sides, for sure. It's just printed in white on the connectors "600w" instead of say "gpu" on one side and "psu" on the other, like I have come across on almost all cables that come with power supplies. I mean.. even some of the cables that came with THIS power supply follow that logic. I'm stumped whether to risk connecting the cable to my new gpu.
