Phanteks Enthoo Evolv Atx Tempered Glass Watercooled Build
28 Oct 2016
After purchasing the new Phanteks Evolv ATX for my computer I had decided my mismatched Components, Sleeveless cables and the massive evo212 cooler was just not the kind of "Eye Candy" worth showing off in a £170 case lol.
I had originally planned on using an AIO cooler but after watching a few videos online I had instantly fallen in love with Custom Loops. As a first time water cooler obviously soft tube would be the best viable option but as a stubborn 21 year old I decided I would take the chances and try Rigid.
With all that aside here is my Final Build and What it had looked like before.
Core Parts:
Phanteks Enthoo Evolv ATX Tempered Glass - Silver
Intel 4790k @ 4.6GHz
MSI Gaming 5 Z97 Motherboard
16GB Corsair Dominator 1866MHz memory
Gigabyte G1 Gaming GTX 960 (Temporary)
2 - Samsung 850EVO 250GB
Corsair AX850 Power Supply
Watercooling Parts:
EK Supremacy EVO Plexi
EK Monarch X2 Ram Block – Acetal/Nickel (Temporary)
EK RAM DIMM Modules Nickel
EK CoolStream SE Dual 240 Radiator
EK CoolStream SE Triple 360 Radiator
5 – EK Pass Through Fittings
Aquacomputer Aqualis ECO 150ml Reservoir
Alphacool Lang DDC Pump
Alphacool DDc Acrylic Top
Alphacool DDC Nickel Heatsink
5 – Alphacool Phobya G-Silent HSP Slim 120mm
1 – Phanteks F140SP 140mm fan
20 – XSPC 14mm Rigid Triple Seal Compression Fittings
9 – XSPC 90 Degree Rotary Fittings
1 – XSPC Ball Valve
1 – Darkside 30mm Extension
2 – Bitspower 8mm Extensions
1 – Bitspower 90 Degree Elbow
2 – Koolance 90 Degree ½” Compression Fittings
2 – Koolance ½” Compression fittings
1M – Mayhems ½”- ¾” Tubing
Mayhems Dye - White
3M - 14mm Acrylic Tube
Misc
NZXT Hue+
2 - NZXT Hue+ Extension kits
Darkside Sleeving – Dark Red, White, Graphite
Shakmodz 4mm Cable Combs
¾” Zip Tie Mounts
Black Craft Foam
Adhesive Magnet Sheets
You need the jpg address:-
Eg:
Code:
https://c1.staticflickr.com/1/433/32036090465_28b1fcd021_z.jpg
Thanks! a lot of time went into the build and im glad it came out the way it did!
There are a few improvements to be made,
i.e The bend from the rad to the cpu block and a 4 dimm ram block.
Also plan on a 1080 Reference and a m.2 drive.
Will keep updated!
