Phanteks Enthoo Evolv Atx Tempered.
2 Jul 2016
Birmingham
Hi all,
Slowly replacing my computer bits and i purchased one of these cases which looks absolutely mint and once i placed everything inside it i noticed that the left side glass panel doesn't screw in fully.
The two bottom screws do not seem to fit in perfectly which leaves a slight gap. Enough to lift the panel and visibly see the gap between the case and the glass panel.
Has anyone else noticed any issues with theirs?
Many thanks in advance
Not had an issue with it. Check that the glass panel is not compressing the rubber around the screw holes as this can cause the panel to sit away or at an angle from the case.
