Phanteks Enthoo Evolv ATX
17 Mar 2009
Hey guys, I'm looking for a case and have seen the Phanteks Enthoo ATX https://www.overclockers.co.uk/showproduct.php?prodid=CA-029-PT&groupid=2362&catid=2674 , what do you guys think of this case? For me there seems to be very limited air vents to allow radiators to breathe, considering the amount of features it has for water-cooling. I'm thinking of either this case or the H440 which from the looks of it would suffer the same problem.
The H440 is pretty limited in its airflow too, compare to the likes of the 750D. Considering the style of case (Evolve/H440) they still perform well overall.
I'd just go for it, if you do want to know (for sure) they'll be a few reviews.
The reviews of it seemed to think that there would be enough room for the fans to get air in and out where needed.
I ordered one in Genmetal. Still just picking and choosing what water bits to fill it with.
Personally not a fan of the cases with a huge ass hole/grill in the front for intakes.
its a gorgeous case for a desk, i didnt personally go for one because i have to put it on the floor
There are a few of us now waiting on the pre-order coming through, so if you can wait to get feedback from us then hold off. I can't see it being a massive issue tbh, the styling for me makes up for any loses in temp performance. Having seen the air temps on bit-tech review I'm happy enough its a safe bet.
