Phanteks Enthoo Luxe Buzz
25 Jan 2006
Birmingham
My new case with Corsair H110i GTX has a lovely buzz/vibration. Anyone else have this combo? Fans are the new Corsair ML120/140mm.
Ordered one of these: https://www.overclockers.co.uk/xspc-280mm-radiator-gasket-wc-247-xs.html. Will put it between the fans and radiator, see if it helps. Only £0.98.
Tried with the 3 top 140mm fans off, and the case is near silent, so definitely think it's something up there.
Currently have the fans in the roof section, with radiator below, pulling air through the radiator. Might try with fans below, pushing air through.
