Phanteks Enthoo Luxe PWM Hub - CPU Fan connection?
25 Nov 2002
I have a Phanteks Enthoo Luxe and Gigabyte GA-Z97X-SLI. It's my first time with a PWM Hub and the manual for the Enthoo isn't totally clear on how to connect the CPU Fan for full functionality.
Would I be correct in saying that the 4 pin cable from the PWM Hub goes to CPU_FAN on the motherboard and the CPU Fan cable goes to CPU_OPT on the motherboard?
Thanks for looking.
I don't own the case, i'd presume the 4 pin header from the fan hub connects to the 4 pin CPU_FAN header on your motherboard, its usually the one at the top above your CPU socket or at the top just to the right.
Thanks for the reply. This is what i've done and it appears to be correct as per the manual. The thing I was a little unsure of is where then the lead from the CPU Fan goes. The assumption is CPU_OPT on the motherboard but I was wondering if the CPU Fan should go back to the hub (although all the other connections on that are 3 pin for case fans etc).
Thanks again :)
