Phanteks enthoo primo - anyone still using one
10 Apr 2015
Hungerford, UK, Earth
I had this case and i wished i hadnt sold it. anyone still using one in a modern PC (or old) and got some build pics
heres mine back in the day..
Also had one, but long gone. Opened the bottom to let one of the 480mm rad breath, and modded the side panel to insert a full glass panel. Good case. Only hated the led strip which would get damaged easily when removing panels.
Yeah I'm still using mine, although currently in the middle of a long overdue rebuild/trouble shooting so the system is currently air cooled in a BitFenix Shinobi. I'll try to remember to put some pics up when I'm putting it back together.
It's a bit worse for wear though, one of the clips for the top mesh snapped off so it doesn't clip in, front mesh/trim doesn't clip in either (got some magnets to hopefully sort that!) and some tape residue on the side where I'd already packed my spares up when moving house and didn't have any thumb scews holding the panel on :-/
Got a 280mm Monsta in the bottom, 240mm mayhems quadpass prototype (which I won on here!) in the front and just picked up an XE480 which will be going in the top (which is the main thing preventing me from moving to another case!).
