Hi all, after a bit of advice on how to get the best out of the cooling in my case..
Currently have a GTX H100I cooling the cpu with the radiator at the top of the case. Fans on the radiator are pulling in , with 3 Phanteks PH F140SP as intakes at the top.
I have 2 rear PH F140SP as exhausts at the rear, 2 PH F140SP intakes at the bottom of the case and 2 more PH F140SP fans as intakes at the front.
CPU seems to keep cool enough but I have 2 GPU inside also.. A gtx 1080TI which runs about 45 idle and a GTX1070 running at 28 ( but that is due to it being mounted sideways at bottom of case as cant fit both gpu in with out temps going mental.
When gaming/mining for a while the 1080TI goes to about mid 70's.. should i be worrried ? Is there any better cooling ideas ? I tried using the top as an exhaust but temps got even higher and all fans kicked in and sounded like a hairdryer.
any advice would be appreciated greatly.
