- 28 Sep 2014
Hi I have a couple of questions regarding my case:
Firstly has anyone modded the Blue LED strip that runs across the top and front panels?
I've seen one guide online that recommends an LED strip 6mm wide or narrower but in the whole of the UK I cannot find any online retailers that sell anything smaller than 10 or 8mm.
I've gone for a red/black theme so looking to swap the blue LED to red.
Also, I swapped the stock fans to Red thermaltake Riing 14 fans purely for aesthetics and I'm using Riing 12's on my H100i GTX but I think they're a bit loud coming from SP120 QE in the past.
My question is, can these 3-pin fans be controlled or slowed down like pwm fan or will I need to change the fans completely?
Cheers in advance.
Cheers in advance.
