PHANTEKS ENTHOO PRIMO QUESTION
18 Jan 2015
on earth
Hi just a quick question about the above case. I intend to get the Asus front base as i like it and it will work nice with my ROG HERO VII board. My question is can the swinging front door case cover be removed ?
As the round dial on the front base sticks out and will provent the case swinging door cover closing .
Thanks
I have a fan controller in mine, akasa fc6. I just moved it back a bit and the door closes fine.
Thanks for replys i did look at the smaller case but it only has 4 bay slots i need 5 min , taking it off would be great if possible or cut a hole in it or as said push it back a bit . The case really is nice and is just what im looking for . again thanks on replys.
There are screws on the inside of the door, around the hinges, so I'm guessing it can be removed (else there would be no point in screws there), though I have not tried myself.
