It can indeed be turned on/off via a button on the top front of the case. HDD led is also blue but very very small.
ok cheers, the blue HDD LED i can live with, just not that long blue bar.
Have you checked the molex connection? On mine one of the pins on the molex connector is a little loose. A few times now after working inside the case the pin has slipped out a bit causing the strip to not work. Not a big deal for me personally as its easily sorted.I think mine blew as it's not working anymore![]()
I'm waiting delivery of a red and black one of these. Kinda excited although the size is a bit daunting. Gonna take my first steps into water cooling.
Yep, it's a back breaker. 17kg before you put any parts into it. God help the watercoolers with multi gpu setups. But it is a fantastic case, hard to believe that such a versatile case can retail for the price. Excellent watercooling support straight out of the box, and a very good case for air cooling too. It is such a well thought out design.I warn u now.. its mahoosive
