Evening folks,
I recently built a new system in a Phanteks Enthoo Pro and everything has been great up until today. I seem to be developing some sort of issue with the power button.
Today when I turned my pc on it powered on for a couple of seconds then powered off, the. Powered on again then off and then on. After a few tries my motherboard detects a problem booting and take me to the bios. Exiting that the pc booted as normal. I used it for about 4hrs powered down then went out.
When I came to turn it on again same thing happened, I did some quick testing and it seems to do this 90% of the time when I use the power button on my case but never when I power on directly from my motherboard. I didn't get to test for long as I had to leave but I'm thinking it could be this.
There has been a couple of days in the last few weeks I have come home from work to find my pc on when I knew it had been shut down.
The power button on this case is really sensitive,holding my hand over it can switch it on. Has anyone else heard of this happening? Or have any other ideas about what could cause this issue.
Here is my full spec just in case:
Asrock z97 extreme6
I7 4790k
EVGA G1 750w
16gb hyper x fury
Gigabyte g1 970
512gb mx100
Ps. There is no oc on the build yet, hence why I'm thinking more of a case problem than me having messed with volts or whatnot.
Thanks for any help.
Asrock z97 extreme6
I7 4790k
EVGA G1 750w
16gb hyper x fury
Gigabyte g1 970
512gb mx100
It is odd I admit. Have you had a look at the connection underneath to see if anything funny is going on there? It certainly sounds like some kind of electrical issue with the button and the wiring under there. Of course, if this is happening with the power supply OFF then run. Run very far indeed.
