** PHANTEKS ENTHOO PRO M - FOR THE CLASSY GENTLEMAN ON A BUDGET **
OcUK Staff
26 Nov 2014
Stoke
We're pleased to introduce the Phanteks Enthoo Pro M, a more budget version of the Pro series, but retaining most of the features which make the Pro such an excellent choice of case. The Pro M has a similar chassis structure, with support for 360mm radiators on the front and top, along with the radiator bracket as standard. The Pro M also includes a rear 140mm fan, a drop and lock SSD bracket and three removable dust filters.
As for the differences, other than the different internal layout and fascia, the Pro M does away with the front 200mm fan, the PWM fan hub and has a different side window, however this is reflected in the price, which at £59.99 inc VAT represents outstanding value for money. The Pro M is available in two colours initially - Black & Titanium Green. The stock is due to land around the end of July for both models. Preorder now!
Phanteks Enthoo Pro M Midi Tower Case with Window - Black @ £59.99 inc VAT
The ENTHOO PRO M focuses on delivering great design without compromising price. Water-cooling builds will be a simple task with the help of our innovative radiator bracket and pump mounting locations. Whether you are a system builder or water-cooling enthusiast, the PRO M will give you unlimited possibilities.
Enthoo Pro M includes 1 x 140mm fan in the rear. Ability to upgrade to additional fans is possible. All fans included are Phanteks’ new redesigned and better performing SP series fans.
Features
- Brushed aluminum look
- Clean interior - Hidden PSU and HDD’s
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 1 Phanteks premium fan - 1x PH-F140SP in rear (140mm)
- 3 different installation areas for radiators (120mm or 140mm form factor).
- Reservoir mounting locations
- 1x Drop-N-Lock SSD brackets included
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equipped with removable dustfilters (1x front, 1x bottom, 1x top magnetic)
- Clean cable management using Phanteks' preinstalled Hoop-N-Loop cable ties
- Removable optical drive cage
Specifications
- Dimension: 235 mm x 480 mm x 500 mm (W x H x D), 9.25 in x 18.9 in x 19.7 in
- Colour: Black
- Form Factor: Midtower Chassis
- Material(s): Plastic Exterior, Steel Chassis
- Motherboard Support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side Window: Yes
- Expansion slots: 7
- Internal 3.5": 8x (2x included)
- Internal 2.5" (dedicated): 3x (1x included)
- Cooling: 120mm Fan - Front: 2x (3x without ODD Cage), Top: 3x, Rear: 1x
- Cooling: 140mm Fan - Front 2x, Top: 2x, Rear: 1x
- Liquid Cooling: 120mm Radiator - Front: Up to 360mm, Top: Up to 360mm, Rear: 120mm
- Liquid Cooling: 140mm Radiator - Front: Up to 280mm, Top, Up to 280mm, Rear: 140mm
- Graphic card Clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- PSU Clearance: 318 mm (12.5 in)
- CPU cooler Clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in), 140mm: 48 mm (1.89 in)
- Package Dimension: 315 mm x 545 mm x 585 mm (WxHxD)
- Net Weight: 7.4 kg (15.4 lbs)
- Gross Weight: 9.0 kg (19.8 lbs)
- Warranty: 5 Years
Only £59.99 inc VAT.
ORDER NOW
Phanteks Enthoo Pro M Midi Tower Case with Window - Titanium Green @ £59.99 inc VAT
Features
Specifications
- Colour: Titanium Green
- Side Window: Yes
- Warranty: 5 Years
ORDER NOW
Interesting case :)
But before committing myself to buying one, I would like to know a little more about the optional HD and SSD brackets.
Which HD and SSD brackets are they referring to.... i.e. What parts, when available, and how much, and will Overclockers be stocking them anytime soon?
Is it possible to mount a Phanteks Enthoo 3.5" HDD Bracket ( https://www.overclockers.co.uk/showproduct.php?prodid=CA-023-PT&groupid=2362&catid=2674 ) to the SSD mounting slots on the PSU cover part in the case main internal side?
Interesting case :)
It comes with 1 x drop and lock SSD bracket. The 3.5" Modular HDD brackets will be sold separately and will arrive shortly after the initial batch of Pro M does. We sell 2.5" single and dual SSD drop and lock brackets already, and also 3.5" HDD drop and lock brackets i.e. the one you've linked to, but it will not fit on the PSU shroud side as there's not enough clearance for a 3.5" HDD.
please can i return my primo for one of these.. i dont have the box, but i do have lots of love to give :D
Is this the green? If so, it's cool but I expect would be very marmite.
I like marmite, but I'm not keen on that green.....
I do, however, think it's great that case manufacturers are offering more colour options to customers, instead of the traditional black or off-white/cream.
