- 14 Mar 2011
Hey all,
Probably not the brightest question but I just want to double-check... I know a few of you guys have this case so I'm sure someone will know
The PWM hub behind the motherboard tray, I've connected the SATA 12V connector to my PSU, and I bought an additional 140mm fan which I've plugged into one of the free 3-pin sockets (for a total of 3 chassis fans connected)
In the manual it says to connect the 4-pin cable to the motherboard's CPU_fan header. If I do that - do I then just connect the cable from the actual CPU fan to the PWM hub (assuming it reaches)? I'm a bit confused because surely the CPU fan's cable is 4-pin not 3-pin?
