Phanteks Enthoo Pro watercooled
26 Nov 2015
Derby
Hi everybody...
since I'm new on the forum I decided to say hello and show You my current rig
(some of you may know me :> hint -> http://www.msi-moa.com/legacy2009.html)
I7 3770k @4.5GHz
Asus Maximus V Extreme
2x4Gb HyperX Savage
Sapphire R9 290 4GB @1050/1375
SanDisk 120GB Ultra II + Seagate 1TB HD103SJ
Sound Blaster Titanium
Its all powered by an Antec signature 850W and hidden in a Phanteks Enthoo Pro
Water cooling:
CPU EK Supremacy Evo
GPU EK R9 290 Fullcover
Alphacool 240 Cooper Rad + Cooltek Exstream Dual 240 Rad
Laing ddc 1rt with Xspc laing ddc top
8/10 fittings
IMG_0707_zpsiwesnf4n.jpg~c100
I'm planning to change the pump to D5 with EK CSQ reservoir (already have it) and change from soft to hard tubing (primochill 10/13). I will update this thread with my progress
sorry for my English ... ;]
I like that. it looks a really clean build and its not cluttered.
every time I see a custom loop a little bit of me starts thinking.... then I look at the prices and I come back to reality with a bump :(
pump and tubing ready
pump with bigger tube and ek multitop tested for leaks
now i need to go and get a heat gun ;] and learn how to bend
edit:
ok .. so this is my first attempt to bend PETG
not very good ... ;] but that first bend is important to understand how it al works
second attempt was much better
although not perfect ;]
anyone has any tips and tricks for me? :)
I've noticed that its crucial to heat the tubing evenly from all sides.
edit2:
third time's a charm, right?
hopefully the rest will be even better ;]
