Phanteks Entoo Evolv ATX - (Fitting E-ATX motherboard help)
13 Jun 2015
Hello,
Would I be able to fit Rampage VI Extreme(x299), the new Apex(x299),
or the Zenith Extreme (x399) motherboards in a Phanteks Entoo Evolv ATX case?
According to product manuals I am missing 1.4cm so I wonder if I would
have any trouble?
Thanks
Phanteks sure is seriously faking E-ATX support...
E-ATX standard has 330mm motherboard width so that case simply shouldn't be advertised as E-ATX case.
Looking pictures while fitting motherboard would likely start covering those cable management holes.
It would definitely be too tight I reckon, I've got a standard ATX sized board in mine and it felt just about the right size. The Evolv ATX can support slightly wider than standard ATX but definitely less than full E-ATX as epc1 mentioned.
I'm sure there is some pictures online of the old Rampage x99 board in a Evolv ATX. I think it fitted but they needed to feed the 24 power cable through first before fitting the board as the board blocks half of the rubber grommets.
I have a z170x gaming g1 in my evolv atx. Not sure how it compares to the rampage. It fits fine but you couldn't get a larger board in there. Just beware the evolv atx has terrible airflow and cooling but does look good. I had to modify it to get some air through the case.
