Phanteks evolv case fans
17 Aug 2005
Swindon
Hi all,
Just a quick question regarding the stock case fans on the evolv case(few years old model).
I checked the specs on these and they seem quite reasonable but am wondering if changing them would see any meaningful change in temps?
My temps aren't terrible, but I recently upgraded to. 2080ti (gigabyte) and it runs ~10 degrees warmer than previous card. With summer coming ambient temps will also raise so seeing if I can improve that.
I have done a bit of research and the Noctua NF A14
Industrial seem promising.
Has anyone else changed the case fans in evolv and make any suggestions?
Thanks
I replaced mine with 5 corsair ML 140mms red led they are great fans and can push a lot of air on low rpm,I'm building my watercooling parts and will be fitting g a 280mm dual fan rad in the roof of my evolv x.
I have a h100i fitted to the roof of the case and have some Corsair mls on that. They are decent but wasn't sure on their suitability as case fans on the evolv due to the front having that panel and restricting the airflow a little.
