OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder we have the improved Phanteks Evolv ITX Glass featuring a tempered glass side panel, along with RGB functionality, a top mounted bracket for installing up to a 280mm radiator and a multifunctional bracket for a reservoir, pump and SSD/HDD. The power and power display buttons are now RGB, and can either be controlled by the button on the I/O panel, or connected to an RGB compatible motherboard using the supplied adapter cable and controlled through the software. Asus Aura, Gigabyte RGB Fusion and MSI Mystic Light Sync are all supported as standard, as well as Phanteks range of RGB strips and the recently released Halos fan frames. There's support for up to 280mm radiators on the top bracket, or 240mm radiators at the front, along with 330mm VGA cards, 200mm CPU coolers and 212mm PSU's. All in all, it's a tasty improvement on the original Evolv ITX for not that much more money.
Stock will be landing in the first week of September, and is available in 3 flavours - Black, Black/Red and White. Preorder now!
Phanteks Evolv ITX Glass Mini-ITX Case - Black @ £76.99 inc VAT
Small black Mini-Tower with tempered-glass side panel, Extensive water-cooling support incl. Dual-radiator mounting & reservoir support, RGB lighting and controls
Only £76.99 inc VAT.
ORDER NOW
Phanteks Evolv ITX Glass Mini-ITX Case - Black/Red @ £76.99 inc VAT
Small black-red Mini-Tower with Tempered Glass side panel, Extensive water-cooling support incl. Dual-radiator mounting & reservoir support, RGB lighting and controls
ORDER NOW
Phanteks Evolv ITX Glass Mini-ITX Case - White @ £86.99 inc VAT
Small white-black Mini-Tower with tempered-glass window, Extensive water-cooling support incl. dual-radiator mounting & reservoir support, RGB lighting and controls
Only £86.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
