Phanteks Evolv X Dual System Build with MiSTer FPGA system possible?
20 Jan 2004
Hey guys.I need some friendly advice and not sure where to start.
I'm thinking of building a new PC (first one in 9 years!) with the Phanteks Evolv X case that's been stuck in the loft that I've never used.
I understand that this takes two PC systems but has anyone built one with a MiSTer FPGA system?
I have a spare DE10-Nano (which is powered by a separate MiSTer FPGA Power Supply 5 Volt 4 Amps) and I also have a spare Taki Udon MiSTer Pi (which is powered via Type C cable with a 5V USB plug).
Are there any big negatives I should look out for?
Is this doable or should I really keep my MiSTer FPGA system separate from my main PC.
Thanks in advance to all replies.
I don’t know much about a MiSTer FPGA but googled it and it seems to be like a rasberrypi size. The Evolv X supports two systems, ATX and ITX. Because the ITX mount is top rear, I’m not sure it would fit. You could possibly mount it on the bottom, or alongside the PSU but I’d be inclined to keep them separate.
